Hick Posted September 12, 2010 Share Posted September 12, 2010 so coming back from the trails on friday my lights got dimmer progressively. Soon as i hit the off ramp, it died. Low battery and everything. The alternator is 4 months old and passed the autozone tester across the board. What else could this be? Btw, its an 87 2.5 ax4 2wd Link to comment Share on other sites More sharing options...
btm24 Posted September 12, 2010 Share Posted September 12, 2010 so coming back from the trails on friday my lights got dimmer progressively. Soon as i hit the off ramp, it died. Low battery and everything. The alternator is 4 months old and passed the autozone tester across the board. What else could this be? Btw, its an 87 2.5 ax4 2wd Old battery is what i would guess. try testing it Link to comment Share on other sites More sharing options...
mvusse Posted September 13, 2010 Share Posted September 13, 2010 Bad connection between alternator and battery. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted September 13, 2010 Share Posted September 13, 2010 Bad battery. Link to comment Share on other sites More sharing options...
gl1200aman Posted September 13, 2010 Share Posted September 13, 2010 Maybe a serious short. The battery would have to be totally shot to drain all the power that the alternator was generating like that. If the vehicle is running the alternator should be putting out enough power to run it with the battery disconnected. Link to comment Share on other sites More sharing options...
btm24 Posted September 13, 2010 Share Posted September 13, 2010 Maybe a serious short. The battery would have to be totally shot to drain all the power that the alternator was generating like that. If the vehicle is running the alternator should be putting out enough power to run it with the battery disconnected. mine was that bad :( Link to comment Share on other sites More sharing options...
Hick Posted September 13, 2010 Author Share Posted September 13, 2010 The book says theres a fusable link in the + wire off the alternator. I'm thinking when the truck got mud covered it shorted something out and blew the fusable link, thus cutting the power from the alternator. :dunno: Link to comment Share on other sites More sharing options...
