MJ cap or Not???
I picked up this 88 MJ and with it came a cap. I am not 100% sure if it is off a MJ or not. it sits about a 1/4 to 1/2 "by the eye" inch lower than the roof line ( but id has no rubber gasket on the bottom. at the rear it lines up perfect and at the front it is about a 1/2 to and 1 inch "by the eye" to narrow. Now the guy I got it off, told me that his father in law had the truck from new, and the cap has always been on it and they are color matched.
Is this a actual MJ toper or did the old man in 1988 get something close enough and cheaper from something ells?
It has been suggested I could be off a Ranger?
If it doesn't fit like mine in the signature, same height as the cab roof line w. the same angle, it ain't original. Your's sounds like a pre-94 S10 cap. It the closest non-original cap for the MJ but is lower than the roof and the sides angle in sharper from the bed to the top.
