jeepdude89 Posted September 7, 2010 Posted September 7, 2010 I have found a nice pair of Tan XJ bucket seats that I will be putting into my MJ. Do I need the female seat belt buckle ends from the XJ too? Or will my bench seat ends work with the bucket seats?
sinkrun Posted September 7, 2010 Posted September 7, 2010 Yes, you could use them as long as there the same type as the bench ones there are two types I think. The bench seat ones will fall down and the bucket ones stand up and are at easy reach. And yes this is a pain when you go around a turn and see the police road spot check.
JeepcoMJ Posted September 7, 2010 Posted September 7, 2010 you NEED them. comanche female ends are soft..no plastic on them to keep them rigid from the floor. cherokee ones are rigid from the floor up...so they won't fall down every time you disconnect them. held in with a T50 torx bolt.
