Pete M Posted March 7, 2011 Share Posted March 7, 2011 brakeline length won't make any change to pressure. look into the dual booster swap. :thumbsup: Link to comment Share on other sites More sharing options...
mvusse Posted March 10, 2011 Share Posted March 10, 2011 I'm nearing completion (waiting for a couple odd minor parts) of my 8.25 + rear disc mod.I used backing plates and calipers from a 1997 ZJ. Two things needed attention;, the backing plate center holes needed to be opened up about 0.010" (I used a 3" sanding drum on a drill press), and the mounting studs on the axle tube ends needed to be replaced with the ZJ studs to account for the thicker backing plate. Other than that, it's all bolt-on. Also, I found this link: http://www.vibratesoftware.com/html_hel ... Angles.htm to be very helpful to understand the relationship between pinion, d-shaft, and output shaft angles. Parallel is good, and there's a couple other factors. Also had to revise the brake lines a bit, and there's a number of ways to do it. The mounting studs on mine were long enough for the nut to go on the whole way with the swap. Link to comment Share on other sites More sharing options...
SW86 Posted March 10, 2011 Author Share Posted March 10, 2011 the mounting studs off the Zj are about a 1/4 of an inch longer maybe a lil less. the stock ones will work but the nut will be at the end of the threads as where the Zj studs have some threads sticking out after the nut is tightened. i guess its a paranoid safety thing but why not for people who havent done the swap if you use the ZJ mounting studs they will be "toed in" when you seat them and youll have to beat the backing plate on. i don't recommend. it can strip the studs. i used my punches to tap down between the studs and the axle to pry them out a bit. went on with no 2 pound hammer after that :thumbsup: thanks again guys! Link to comment Share on other sites More sharing options...
