how do you install fog lights? my gf's dad have me some right outa the box and came with all the gear to install but when i went to put it on the front bumper they tilted. how do you get around that? and if any body as any right links to right ups this would be a great help thanks :D
Shouldn't the lights have bolts through them that tie into the bracket that move up and down when loosened? Should be as easy as loosening the bolt, adjusting the light, and tightening the bolt.
Are they tilting because the back of them is touching the grill?
Most of the aftermarket lights just have a simple bracket that allows you to adjust the tilt on them.
I would suggest posting a picture for more assistance.
yeah they hit the grill ill post pics tomarrow when i get home.
I think the OEM fog lights were not very 'deep' and had the mounting bracket towards the extreme rear of the light to prevent this issue.
Good luck.
