AMC-2.5 idle change ?
My engine once heated up normally idles at 750rpm nice steady and smooth . . . Now the idle has dropped to 625-575rpm and it has a bit of a shimmy or shake to it . . .
What would cause this to happen ?
i been driving the truck everyday 3times a day for 9Mo this is the first i have seen it do this . . .
Mike
You might want to check to see if the idle speed actuator is still working or if it has come unhooked. It is a little plunger like device that pushes on part of the throttle linkage at the throttle body. Sounds like it might not be working like its supposed to. Good luck.
I removed the motor speed adjuster cleaned it all up and shot some grease onto it, and so far it working idles holding at 750rpm not sure if it was a cure or just a stall . . .
tho the 750rpm idle is not smooth like it once was checked air filter nice and clean, tune up time again ?
Mike
  • 2 months later...
