Rymanrph Posted August 12, 2010 Share Posted August 12, 2010 I need a bushing for my trackbar. I used the one that came with my '97 Dana 30. Autozone lists different part number for the actual track bar for a 1990 comanche and 1995 Cherokee and a 1997 Cherokee. They all weight different amounts as well. So, did the track bar change that much? The one for the comanche is about $20 cheaper than the Cherokee two. I don't need a new track bar, but I want to make sure I get the right bushing. Link to comment Share on other sites More sharing options...
UNL1MTD Posted August 12, 2010 Share Posted August 12, 2010 I used a trackbar from my 05 TJ in my 87 MJ and haven't had a single problem in the three years I've had it in there. Not sure if the bushing from a new trackbar would or wouldn't work in an older trackbar though. Link to comment Share on other sites More sharing options...
mkbruin Posted August 12, 2010 Share Posted August 12, 2010 The mount itself will be the same, but the trackbars came in various sizes. You will need to match up the correct mm diameter for the bushing to work. Link to comment Share on other sites More sharing options...
Rymanrph Posted August 12, 2010 Author Share Posted August 12, 2010 Ok, since the track bar I'm using came from a '97 XJ, then that's what I'll ask for. Link to comment Share on other sites More sharing options...
