Fred Padgett Posted November 7, 2006 Share Posted November 7, 2006 The previous owner of my sons Comanche with the 4.0L broke off the O2 sensor. Any idea on the best way to get it out and install the new one. also He needs to replace the speedo cable, any tricks on that one. by the way it is an auto trans. Link to comment Share on other sites More sharing options...
500 MJ Posted November 7, 2006 Share Posted November 7, 2006 speedo is simple, just undo the dash and get to the back of the guages and unclip it. it should just unscrew from the tranny... Link to comment Share on other sites More sharing options...
Stumpy Posted November 7, 2006 Share Posted November 7, 2006 Fred Padgett said: brake fluid works pretty good as a rust buster on the O2 sensor just make sure its not hot. sometimes you need a special socket for the sensor too. Hah! I bought an O2 sensor socket. Ain't no way on God's green earth to fit it up between the frame rail and the manifold to get it on the sensor. I ended up doing what I've always done -- used a large, economy size metric Crescent wrench. (That's a joke, for those of you too young to know WTF a Crescent wrench is.) Link to comment Share on other sites More sharing options...
Fred Padgett Posted November 13, 2006 Author Share Posted November 13, 2006 You were right I have about three different O2 sockets or wrenches, and non of them would work, I had to resort to an old favorite of mine, a Vise Grips that has a piece of 1/2" ar stock welded onto the handle. it was slow but it got it out. Now that the new one is in and working, we still have an exhaust leak. It appear that the EGR tube is leaking where it threads into the exhaust Manifold. Anyody got any hints on that one? thanks for all of the replies and support Link to comment Share on other sites More sharing options...
