i have some surface rust on the bed, i've never had to remove rust so I'm wondering, do I just get a wire brush and old fashioned elbow grease or is there some liquid rust remover stuff I should put on first, then wire brush it?
well I hope for you that its only surface .....
I hope its not rust comming from the inside peaking out
start with a quick sanding
if not wire brush
if not grinder
if not cut and weld
mouhahahaha
