clear taillights
I've got a hammer... :brows: You'll have the clearest taillights on the block. :D
brilliant!
as a side, considered making your own? Plexi in the 3/16 flvor isn't har to form with a little heat, hell even 1/4 isn't that bad. Heat it evenly where you're bending it and use an old tail light as your tempplate. Once you've got the curve down I'd gut a stock tail light and use it as the base. Paint the inside with some reflective chrome paint and button it up.
Retention is the only problem I fore see, but you're on your own for that one.
