Drahcir495 Posted November 6, 2006 Share Posted November 6, 2006 I would like to know how to properly identify an AX15 when it is not attached to the engine, or in the vehicle. I know how to tell the difference between a BA10 and the AX15, I want to make sure it is not an AX5 for the 4 banger. Thanks, Rich Link to comment Share on other sites More sharing options...
87manche Posted November 6, 2006 Share Posted November 6, 2006 easiest way is the spline count. AX-15's all have a 23 spline output. AX-5's were 21 I believe. Dimensionally they are very similar, with trans length being the same for both. The AX-15 has more pronounce structural webbing. I'd recommend you go to novak-adapt.com and look in the knowledge base there for pictures and dimensions. Link to comment Share on other sites More sharing options...
Drahcir495 Posted November 6, 2006 Author Share Posted November 6, 2006 easiest way is the spline count.AX-15's all have a 23 spline output. AX-5's were 21 I believe. Dimensionally they are very similar, with trans length being the same for both. The AX-15 has more pronounce structural webbing. I'd recommend you go to novak-adapt.com and look in the knowledge base there for pictures and dimensions. Thanks for the input. I will check Novak out. Link to comment Share on other sites More sharing options...
jeepthing07 Posted November 7, 2006 Share Posted November 7, 2006 The AX15 has a aluminum intermediate plate while the AX5's is steel so if you see a rusty band around it its a AX5 Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 7, 2006 Share Posted November 7, 2006 The BA10 is also a two pieces case. Its like a clam chell its split right down the middle!! Its also only found behind 6 cyls. CW Link to comment Share on other sites More sharing options...
mjeff87 Posted November 7, 2006 Share Posted November 7, 2006 The AX15 has a aluminum intermediate plate while the AX5's is steel so if you see a rusty band around it its a AX5 Very interesting.....thanks for that little tidbit of info :cheers: Jeff Link to comment Share on other sites More sharing options...
Drahcir495 Posted November 8, 2006 Author Share Posted November 8, 2006 The AX15 has a aluminum intermediate plate while the AX5's is steel so if you see a rusty band around it its a AX5 Very interesting.....thanks for that little tidbit of info :cheers: Jeff That is a nice tip! Looks like Friday I will have an A15 with bellhousing. This one came out of an XJ, so it should be a perfect fit. I have been waiting a while for a XJ/MJ specific AX15 Link to comment Share on other sites More sharing options...
