woody62 Posted July 23, 2010 Share Posted July 23, 2010 what is the correct oil to put in the my 5 spd trans? Doesn't look like 90w. Link to comment Share on other sites More sharing options...
whowey Posted July 24, 2010 Share Posted July 24, 2010 The factory recommended fluid is 75w-90 GL-5 fluid. But from the pictures Correy has of his AX-5 rebuild, it appears to have bronze synchro rings in it. So you would want to run a GL-4 fluid in it. Now if you have the T-5, which I don't think came in '87 then you want to run a Synchromesh type of fluid. Link to comment Share on other sites More sharing options...
woody62 Posted July 24, 2010 Author Share Posted July 24, 2010 we are putting a 5 spd in it. We can't find GL4 Only GL4 and GL5 royal purple. Is that OK to use??? Link to comment Share on other sites More sharing options...
woody62 Posted July 24, 2010 Author Share Posted July 24, 2010 I'm told this is a 1986 5 spd. Link to comment Share on other sites More sharing options...
kar120c Posted July 24, 2010 Share Posted July 24, 2010 You can't go wrong with Royal Purple or Redline IMHO. I've had various manual transmissions between the multiple jeeps I've owned and have used Redline MTL in all of them. Link to comment Share on other sites More sharing options...
whowey Posted July 24, 2010 Share Posted July 24, 2010 You can't go wrong with Royal Purple or Redline IMHO. I've had various manual transmissions between the multiple jeeps I've owned and have used Redline MTL in all of them. Whoa there.... Redline MTL is a GL-4 not a GL-5... RP doesnt offer a GL-4 that I have seen. Redline, Amsoil and a couple of other high end manufacturers offer GL-4 fluids still. Link to comment Share on other sites More sharing options...
kar120c Posted July 25, 2010 Share Posted July 25, 2010 Ran MTL in a T5, NV3550 and AX-15. Never had any problems, all trans had 150+k on them with the fluids. :dunno: T5 was especially picky. First AMC recommended ATF then later switched to 90w gear oil. Later they said use GL-3 I think. Shifted like crap with all oils until I tried MTL (80w). Worked great, smooth shifting and no noisy gears. I've come to find that AMC / Jeep never really made up their mind on correct oil for their manual transmissions. It has always changed back and forth to one or another. :hmm: Link to comment Share on other sites More sharing options...
woody62 Posted July 25, 2010 Author Share Posted July 25, 2010 :bowdown: Redline MTL So where do you buy this stuff, cost? and how much do I need? Can it be added to what I have or do I have to empty it all and replace? Link to comment Share on other sites More sharing options...
comanche09 Posted July 25, 2010 Share Posted July 25, 2010 I have run Mobil 1 10w-30 in my AX with no issues. Recently switched to Redline MT-90 and noticed no difference in shift quality, but I do have a warm and fuzzy now knowing that Redline is in it. :brows: Link to comment Share on other sites More sharing options...
kar120c Posted July 25, 2010 Share Posted July 25, 2010 You can order Redline online through jegs or summit but you get hit with shipping. I've found best retail place to buy Redline is Baxter's. For Royal Purple, Napa seems to be the best bet. O'Reillys, Autzone, etc.. don't seem to carry that stuff anymore. At least not any of the local stores in my area. Link to comment Share on other sites More sharing options...
woody62 Posted July 27, 2010 Author Share Posted July 27, 2010 OK. I ordered Redline. Thanks! Link to comment Share on other sites More sharing options...
