mdwatson Posted July 22, 2010 Share Posted July 22, 2010 Hello I'm new to the forums. I have a 86 Mj with a 2.5 that needs a possible new engine. I was wondering if the intake and exhaust and everything else from my 86 will bolt up to a 84 2.5? Link to comment Share on other sites More sharing options...
Pete M Posted July 22, 2010 Share Posted July 22, 2010 low compression? rod knock? and welcome! :waving: Link to comment Share on other sites More sharing options...
mdwatson Posted July 22, 2010 Author Share Posted July 22, 2010 I think rod knock. Motor sounds good until about a couple miles down the road then it starts knocking. It has 248,000 miles on it. Link to comment Share on other sites More sharing options...
Pete M Posted July 22, 2010 Share Posted July 22, 2010 might just need new bearings. :dunno: I've read that any 2.5L AMC lower block from 84-04 (or whenever they switched to the 2.4) can be swapped in with minimal effort. :thumbsup: Link to comment Share on other sites More sharing options...
Eagle Posted July 22, 2010 Share Posted July 22, 2010 The '84 and '86 engines are basically the same. But the '84 was carbureted and the '86 was throttle body injected. What I don't know is if the intake and exhaust port heights and shapes changed when the went to injection. It's worth a look. The worst case would be using the head off the other engine. Link to comment Share on other sites More sharing options...
