I have removed my old worn out cables but I would like to replace them.
Here is the problem:
The hole in the backer plates is now oval and is to big to securely fasten the push-in clips of the cables. I do not want to replace the backer plates on a Dana 35 because it is a complete waste of money so what do I do? Sorry I didn't take any pictures but I'm sure everyone has had this problem on one or more cars or trucks.
I guess I could have someone weld on a grade 8 washer to the back side but I don't have a welder myself. Any suggestions??
There is your answer brother!!
Are you near enough to CT? I'll gladly help you out!!
CW
Why would the washer have to be welded, and why would it have to be grade 8?
If its being welded a grade 8 is thicker and harder. making it a much better candidate to being welded.
Bepending on the size of the hole/damage it may/could work without welding. But welding it makes for a better/stronger repair... not getting lazy in your "older" age are you my friend?? :wavey:
CW
CW
Me? Lazy? OLD!?!
Just a-wonderin', is all. The hole is still there in the backing plate, just a bit egged out. The washer isn't going anywhere, so I don't see how strength would be at all a factor. And thicker, in this case, is not a good thing. Too thick, and the retaining fingers on the cable end can't snap out and do any retaining.
To be honest, unless the holes are REALLY hogged out, I think the first thing I would try is putting the cables in and spreading the fingers a bit wider with a screwdriver or pliers.
