Slave Cylinder Location?
Unless he has an 86(like his sn implies), or an 87-92 that's been converted, then yes, he's got an internal slave.
If you do indeed have an 86, then it's on the passenger side, bolted to the bellhousing. Mentioning having a yoda before, you're probably looking around on the engine side, our slaves work in the opposite direction.
93 AX-5 with 86 Bellhousing and clutch setup in my 91 w/ 2.5
