Pollockzrodz Posted July 7, 2010 Share Posted July 7, 2010 Hey guys long time no posts I just recently bought another mj project soon to be a full build thread haha. It has the ax15 2wd 5spd trans and I was wondering if this trans could be made into a 4wd ax15 trans since they arent that easy to find around my way cheap. If it can what needs to be done and what parts do I need?? I was thinking the rear tailhousing off of a 4wd trans but does the output shaft need to be swapped also? has anyone done this please let me know I honestly havent even looked at an ax15 in along time since Ive been doing chevys latly so I don't know what this would require. thanks alot! Link to comment Share on other sites More sharing options...
64 Cheyenne Posted July 7, 2010 Share Posted July 7, 2010 First question: Yes Is it worth it, no. It requires swapping out the mainshaft and tail assy. Pretty much the guts out of a 4x4 AX15. At that point you'd be miles ahead to just swap in the 4x4 AX15. Besides, to swap those parts you would have to cannibalize and destroy a perfectly good 4x4 tranny. IMO not worth the time money and effort, bite the bullet, and swap correct tranny in. Link to comment Share on other sites More sharing options...
Geonovast Posted July 7, 2010 Share Posted July 7, 2010 Unless you found any already dead 4wd AX-15 with a good output shaft and tail section.. then it's not really worth it. As stated, you'd be taking apart a 4wd AX-15 and a 2wd AX-15 to make a 4wd AX-15. It'd probably be harder to find the individual parts than a whole 4wd trans. Link to comment Share on other sites More sharing options...
