camjeep3 Posted June 29, 2010 Share Posted June 29, 2010 well took the truck down to the barn for some maintainance before my upcoming wheeling trip. changed engine oil and filter then drained the t case( hardly any fluid :oops: ) and then the tranny. first i pulled the fill plug off but what was weird is that fluid started coming out, and not just a few drops it leaked a good bit out when it was done i put the plug back in and figured id leave it be. so my question, how did that happen? did someone over fill it from the top? would it make a difference that i had the truck in 1st just confused me. Link to comment Share on other sites More sharing options...
Eagle Posted June 29, 2010 Share Posted June 29, 2010 Are you certain the plug you took out was the fill plug and not the drain plug? Link to comment Share on other sites More sharing options...
camjeep3 Posted June 29, 2010 Author Share Posted June 29, 2010 it was on the side up top.... the drain is on the back lower. correct? Link to comment Share on other sites More sharing options...
camjeep3 Posted June 29, 2010 Author Share Posted June 29, 2010 forgot to add... its a puke goat Link to comment Share on other sites More sharing options...
Wildman Posted July 1, 2010 Share Posted July 1, 2010 If it was the plug on the passenger side, yes, that's the fill plug, the drain is in the rear of the BA10. I too had this problem, and I'm thinking it's from the last time I changed/filled it, I think I had the back end jacked up, couple weeks ago I was checking everything, the had the front jacked up, and when I pulled the plug, the 70W90 started pouring out :eek: Which end did you have jacked up??? Link to comment Share on other sites More sharing options...
