MjPioneer Posted June 28, 2010 Share Posted June 28, 2010 After all my ingition problems I routed the problem down to this soliniod looking thing. From what I have found the battery runs to it via power cable, and the ingition runs a signal wire to it. It is located in the jumble or relays behind the battery, if you can't tell it is the large silver rectangular thing. I need to replace it to get the ignition to work as it's suppose to. For the time being I have by passed to a push button for that neat ricer effect. What is it called and where can I find a new one? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted June 28, 2010 Share Posted June 28, 2010 it's the starter relay. Link to comment Share on other sites More sharing options...
Harper Posted June 29, 2010 Share Posted June 29, 2010 .....and you can find one from Rock Auto parts http://www.rockauto.com for as little as $8.87, or as much as $37.79. But make sure you look under Cherokee 4.0; it's not listed under Comanche 4.0 Link to comment Share on other sites More sharing options...
