'89 Comanche "little blue"
Here it was when I got it.
'89 Comanche 4.0 BA10 NP231, SOA rear, home brewed spacers front, 33's
Now in the shop patiently waiting
Cherrybomb glasspack
BA10 to AX15 swap
width=1100 height=825http://i41.tinypic.com/2e50dxe.jpg[/img]
width=1100 height=825http://i42.tinypic.com/flzrs2.jpg[/img]
The all mighty Comanche Dana 44 :bowdown:
width=1100 height=825http://i44.tinypic.com/i4itq8.jpg[/img]
Any guesses why my lights didn't work? :dunno:
Header panel, Bumper, and Rad pulled
Current Plans include:
New exhaust manifold
closed to open cooling system
Aussie locker (Ordered)
New shocks
New front U-Joints
New LCA's
Lift coils instead of home brewed coil Spacers
Nothin to major, just lookin for a fun, capable bush toy
(Pictures came off a 7.2 megapixel camera, don't think I had the settings right)
edit**Could somebody fix my picture links?
Put the new manifold. If you "massage" a little a H.O. manifold will bolt right up.
Also:
Bolted on some newer Rancho rs3000's,
Got my wiring working for the most part.
Cleaned throttle body,
Extended the wires on the O2 sensor so as they will work on a Cherokee downpipe.
Took about half as long to put the manifold in as it did to take it out
Doesn't seem like much when I write it down, but it was all very time consuming.
All this has took past in the last 3 months, just never got around to making a buildup
And now for the recent:
-Couldn't get an Aussie due to them being on back order, but the guy gave me a lock right for the same price, it's installed in the carrier. But found out I needed new axle seals.
-Got the exhaust just about finished ned one more weld.
-Got most of the wirin done, P.O. lit it on fire and didn't bother rewiring lights.
-Found out my fuel pump is screwed, so I am in the process of trying to make a tank out of a '89 ford F150 fit. (if it doesn't I'll put a tank in out of an old cherokee)
-Need a shift linkage for the AX15 due to using it elsewhere.
-Still need rear shock mounts.
-Re installed the closed cooling system again as the other radiator for open conversion leaked like crazy.
-Got some different LCA's due to P.O. "modifying them to minimize tire rub" :shake: Pics when I swap them out.
Sorry for the lack of pics but cannot find the camera :oops:
