dakal Posted June 25, 2010 Share Posted June 25, 2010 will a bell housing and a nv3500 from a 97 4 cylinder wrangler fit on a 4.0 liter 1988 mj? :dunno: Link to comment Share on other sites More sharing options...
Geonovast Posted June 25, 2010 Share Posted June 25, 2010 Pretty sure no 4 poppers got a NV trans... should be an AX-5. And NO. 4.0 and 2.5 use completely different bolt patterns. Link to comment Share on other sites More sharing options...
dakal Posted June 25, 2010 Author Share Posted June 25, 2010 that was a fast answer. thanks!! 16 mins Link to comment Share on other sites More sharing options...
dasbulliwagen Posted June 25, 2010 Share Posted June 25, 2010 What year did the wrangler get the 2.4 neon motor? Though I'm pretty sure the bellhousing wouldnt fit even then. Link to comment Share on other sites More sharing options...
jpnjim Posted June 25, 2010 Share Posted June 25, 2010 will a bell housing and a nv3500 from a 97 4 cylinder wrangler fit on a 4.0 liter 1988 mj? :dunno: NV3500 is the Chrysler version, that has a cast in bellhousing (one piece with the transmission, yeah that was a stupid idea. :yes: ) NV3550 was the version used on Jeep's (4.0L), starting in 2000. It used a separate bellhousing (same bell as the AX-15, for interchangeability) Some AMC/Jeep 4 cylinders did get NV3550's behind them, but only when used in Dakota's. And like everyone said, 4.0L's have a different bell pattern than 2.5L's. 4.0L's got the same bell pattern as 1972+ AMC/Jeep L6's & 66-91 AMC V8's. 2.5L AMC's got the metric GM bell pattern. I don't know what year Wranglers switched to the Neon 4cyl, I had already stopped caring by then. :D Link to comment Share on other sites More sharing options...
dakal Posted June 26, 2010 Author Share Posted June 26, 2010 thanks guys. i'm just trying to get an external slave and the related parts. thought this might work. Link to comment Share on other sites More sharing options...
