front end
i want to upgrade to the newer front end off the newer cherokee. i just wanted to know if it just bolted on or does it need some moding? and what parts do i need to grab to do it
What parts ? LCA's , UCA's , coils . They can be done for a major improvement over stock . Non disco HP D30's were common in the 90"s , brake upgrades and motor upgrades
as well .
Let us know what you want to do ..
WOOOPS , Sorry when I hear front end , I start thinking of 90% of the whole truck is front end .
Header panel and front clip ? New style fenders and doors , front header panel , lights , wiring and vac canister relocation ?
What else ? Oh' the new style strikers in the jams !
with the front end (header panel, fenders, bumper) it is direct bolt on for 87 and up Comanches you just need to do a little wiring. only problem is if you just swap the header panel and leave the old fenders it will have a little gap where they meet and there is no way to bolt the header panel on the bottom because the new fenders have a stud on them for that. 86 I believe you need to do some modding. viewtopic.php?f=9&t=11270
doors will need the striker changed and then I believe they will fit fine.
