MancheKid86 Posted June 20, 2010 Share Posted June 20, 2010 my tranny is leaking from where the yolk goes in, can this be fixed? or should i go ahead and buy the 4.0L HO engine with ax 15 tranny? Link to comment Share on other sites More sharing options...
Geonovast Posted June 20, 2010 Share Posted June 20, 2010 Buy a new seal. Last time I bought one(for a 231, but I think it's the same part, it was $7 at Carquest. Motor swap for a leaking output seal is kind of like renting a steamroller to squash an ant. Link to comment Share on other sites More sharing options...
kastein Posted June 22, 2010 Share Posted June 22, 2010 Simple install, too, drop the driveshaft, pry out the old seal, press in the new one, lube the lip of the seal and put the driveshaft back in place and you're done. Link to comment Share on other sites More sharing options...
