MJ is dead Posted June 19, 2010 Share Posted June 19, 2010 Ok so here's the story Last week I left my lights on at work, came out to a dead battery, duh. So we tried to jump it, no salt. Let it charge for awhile, then tried jumping it again, still no luck. Friend borrowed me a battery to get me home, but it was waaaaaay too big. I don't know the specs, I just know it was way bigger than the stock MJ one. That one lasted another oh...50 miles before it died, in the meantime I had the stocker on the charger at home, so after being limped home 50 miles, I decided to put the right battery back in my mj, that lasted until today. Alright, so a battery won't hold a charge, must be the alternator right? Nope. The alternator bench tested fine. I'm at a loss fellas. Brand new battery in january, and the alt. Is fine. What's next? Link to comment Share on other sites More sharing options...
Harper Posted June 19, 2010 Share Posted June 19, 2010 Any chance that there's another drain on it somewhere after you shut it down? Link to comment Share on other sites More sharing options...
MJ is dead Posted June 19, 2010 Author Share Posted June 19, 2010 That would make sense, if it had been dead a day or two after i put the fresh battery in. But I put the battery in last sunday, and its lasted this long. if I had a draw, I probabaly would have noticed by now Link to comment Share on other sites More sharing options...
Eagle Posted June 19, 2010 Share Posted June 19, 2010 if I had a draw, I probabaly would have noticed by now That depends on how heavy the draw is. For example, the clock is a constant draw, but how many dead batteries have ever been caused by the clock? Link to comment Share on other sites More sharing options...
MJ is dead Posted June 19, 2010 Author Share Posted June 19, 2010 Cables were pretty nasty and corroded, so I'm gonna swap those out for starters, as well as the clamps. Also, taking the nut off the stud on the ground-impossible. I had to cut all the wires going to it, and ended up spinning out the whole stud. I'll be replacing that with a bolt And Eagle....I don't have a clock :rotfl2: Link to comment Share on other sites More sharing options...
1987Comanche Posted June 20, 2010 Share Posted June 20, 2010 What about the cable from the alternator to the starter solenoid (assuming Renix era)? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 20, 2010 Share Posted June 20, 2010 Have you started it, placed a voltmeter across the batt terminals, and read the voltage at 1500 RPM or so? Should be at least 13.5VDC. Link to comment Share on other sites More sharing options...
MJ is dead Posted June 20, 2010 Author Share Posted June 20, 2010 No don I hadn't. I knew that was one way to see if I had charging going on, but didn't have a multimeter till today (when its too late) I pulled the little plastic cover off of where all the relays and crap are and noticed I had a shorted positive wire, what it goes to I don't know. Its possible we burnt it out when we were jumping it. It was like a freaking monsoon it was raining so hard that night. Hopefully that's it. If not, I have new cables, terminals, ans a new battery strap anyway. Also pulled the bumper today and noticed a little green wire behind the vacuum blimp. Has a female spade connection on it, any idea what it goes to? :dunno: Link to comment Share on other sites More sharing options...
Eagle Posted June 20, 2010 Share Posted June 20, 2010 Also pulled the bumper today and noticed a little green wire behind the vacuum blimp. Has a female spade connection on it, any idea what it goes to? :dunno: The right side horn. If your truck is a base model, it doesn't have dual horns. Link to comment Share on other sites More sharing options...
Unglar Posted June 20, 2010 Share Posted June 20, 2010 I pulled the little plastic cover off of where all the relays and crap are and noticed I had a shorted positive wire, what it goes to I don't know. I had this same problem last week and found one of those wires was loose. My guess is after you fix the burned out wire your problem will be gone. Link to comment Share on other sites More sharing options...
MJ is dead Posted June 20, 2010 Author Share Posted June 20, 2010 I certainly hope so unglar :wall: Link to comment Share on other sites More sharing options...
MJ is dead Posted June 21, 2010 Author Share Posted June 21, 2010 Got it all back together, tested the voltage before starting it read 12.5 (fresh off the charger, so a little high, but no biggies) I started up the MJ and it read 14.2, so again a little high, but that definitely means its charging. Woohooo! Fresh cables and fixed a few connections, replaced the belt while I was at it. Thanks guys! :thumbsup: Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 21, 2010 Share Posted June 21, 2010 :thumbsup: Link to comment Share on other sites More sharing options...
Unglar Posted June 21, 2010 Share Posted June 21, 2010 :cheers: Link to comment Share on other sites More sharing options...
Harper Posted June 22, 2010 Share Posted June 22, 2010 Oh yeah, a shorted positive would definitely cause a power draw :yes: Link to comment Share on other sites More sharing options...
