SchneiderFishing Posted May 29, 2010 Share Posted May 29, 2010 So I went up to Midas to have the breaks and muffler looked at. Of course the brakes needed work and the muffler needed replacing. 1990 4.0 Long Bed Automatic. What I didn't expect was to find a lead at the fuel sending unit. Also there seem to be a few bolts and screws that indicated that there may have been some sort of skid plate around the gas tank or maybe near the gas tank to protect the fuel sending unit and hoses and wires??? Any ideas what was there?? Link to comment Share on other sites More sharing options...
maddzz1 Posted May 29, 2010 Share Posted May 29, 2010 Does your tank still have the plastic skid plate around it? Link to comment Share on other sites More sharing options...
jimoshel Posted May 30, 2010 Share Posted May 30, 2010 Jeep engineers realized Jeepers wouldn't just arbitrarily swap there gas tanks so they designed a plastic shield to fit under the gas tank to catch and hold dirt and moisture so the tank would rust out faster. Link to comment Share on other sites More sharing options...
SchneiderFishing Posted May 30, 2010 Author Share Posted May 30, 2010 What plastic cover? Just the 22 gallon gas tank with a couple of straps. Anybody got any pictures? Link to comment Share on other sites More sharing options...
jimoshel Posted May 30, 2010 Share Posted May 30, 2010 Look at the 2 straps holding the gas tank. If there are 2 studs on each strap then it had a factory installed plastic shield. If there are no studs then it didn't. If you haven't gotten a satisfactory answer tomorrow let me know and I can send a couple pics. Can't now cause it's dark outside and I'm afraid of the boogy man. Link to comment Share on other sites More sharing options...
Eagle Posted May 30, 2010 Share Posted May 30, 2010 SchneiderFishing said: What I didn't expect was to find a lead at the fuel sending unit. Also there seem to be a few bolts and screws that indicated that there may have been some sort of skid plate around the gas tank or maybe near the gas tank to protect the fuel sending unit and hoses and wires??? The fuel sending unit is inside the tank. It doesn't need a skid plate. Standard equipment on the MJ was a plastic baffle that hung off the tank straps to serve as a gravel guard ... nothing more. Steel skid plates were optional, but they protected the bottom of the tank, not the fuel pump area. Link to comment Share on other sites More sharing options...
maddzz1 Posted May 30, 2010 Share Posted May 30, 2010 I have the steel skid and try to get some pics up of that if you want. Link to comment Share on other sites More sharing options...
SchneiderFishing Posted June 1, 2010 Author Share Posted June 1, 2010 Pics would be great guys Link to comment Share on other sites More sharing options...
