comanche09 Posted May 25, 2010 Share Posted May 25, 2010 Ok, here is what I installed: -'95 XJ External Slave Bellhousing mated to a '90 AX-15 (same size input shaft and pilot bearing as the Ba-10), using a mopar '95 XJ one piece pre-bled plastic master/slave assembly. -New Pilot bearing, New Clutch, New Throwout Bearing I finally got everything buttoned up tonight, but now she won't go into gear when running? The clutch pedal has good resistance (better than pre-swap). It grinds when I try to go to Reverse and it won't go into any forward gear. With the truck off, I can shift through all the gears no problem. :???: I checked the slave pushrod and it is seated in the fork cup. I tried to turn the adjustment? nut on the opposite side of the bellhousing, but it just turned with the bolt... :???: :( Quote Link to comment Share on other sites More sharing options...
Geonovast Posted May 25, 2010 Share Posted May 25, 2010 Did you swap the external slave bearing retainer onto the 90 trans? Internal External Quote Link to comment Share on other sites More sharing options...
comanche09 Posted May 28, 2010 Author Share Posted May 28, 2010 Hi Geonovast, Yup that was the problem... duh :dunce: . After reading volumes of info on this swap I somehow missed that important detail. :doh: Got the part next-day air from man-trans LLC out of Tallahassee, FL for $80 including seal and rtv, dealer lists it at $302. This trans is like night and day compared to the pukegoat! :banana: Quote Link to comment Share on other sites More sharing options...
Geonovast Posted May 28, 2010 Share Posted May 28, 2010 Glad it worked. :thumbsup: Little pricey though. :ack: From what you described, it sounded like the clutch fork was binding up on the input shaft. Quote Link to comment Share on other sites More sharing options...
knever3 Posted May 29, 2010 Share Posted May 29, 2010 Great advice, I am thinking about doing the same thing, I will watch out for this part. Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
