shawn Posted May 25, 2010 Share Posted May 25, 2010 its on the 86 4x4 ( 2.5, 5spd) and the clutch seems to work fine but when it's first applied, if applied slowly it just goes down and does virtually nothing, but when depressed quikly it works well. also when pumped like pumping a brake pedal it also works very well. fluid is full, no sign of leaking. all suggestions appreciated. Link to comment Share on other sites More sharing options...
Automan2164 Posted May 25, 2010 Share Posted May 25, 2010 Sure it's not leaking up by the firewall? Rob L. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 25, 2010 Share Posted May 25, 2010 Internal seal leaks at either the slave or the master sounds like. Youll probably need to replace both.... it should be external slave, so should be no big deal.... you won't need to pull the tranny! Link to comment Share on other sites More sharing options...
vaquaro Posted May 25, 2010 Share Posted May 25, 2010 Internal seal leaks at either the slave or the master sounds like. Youll probably need to replace both.... it should be external slave, so should be no big deal.... you won't need to pull the tranny! :agree: Link to comment Share on other sites More sharing options...
