kar120c Posted May 24, 2010 Share Posted May 24, 2010 So I'm putting my block together after all my parts came back from the machine shop. My block didn't have any codes (i.e. P, M or PM) stamped on it so it *should* be a standard size crank / rods. Crank came back with .010 / .010. My bearings say .010 on both the box and stamped on the bearing itself. Crank spins freely before caps. Yes bearings are oriented corrently :D I also used assembly lube. When I install the caps (arrow facing front) and tighten bolts finger tight, I can't spin the crank. I have to use a big-@$$ socket wrench on the snout and even then I can barely turn it. :wall: Link to comment Share on other sites More sharing options...
jimoshel Posted May 24, 2010 Share Posted May 24, 2010 Your going to have to mike your crank and the bearings. One of them is off. I have received cranks from the machine shop that were not ground properly. I have also purchased bearings in boxes that were mis labeled. The label on the box was correct but the contents were wrong. Link to comment Share on other sites More sharing options...
mfpdm Posted May 24, 2010 Share Posted May 24, 2010 I had the very same thing happen. Arrows were pointing in the right direction however, if you looked at the numbers, 1-6 was upside down from 7. 7 is the key because it can only go on one way. Check and make sure all the numbers can be read from one side with none of them upside down. I ended up replacing the new bearings because I used a big @ss wrench to turn the crank and scored the new bearings before I found out what I wrote above. :cheers: Link to comment Share on other sites More sharing options...
kar120c Posted May 24, 2010 Author Share Posted May 24, 2010 Thanks for the info. I went through some old photos I took and it looks like the engine originally had the bearing caps with the > mark pointed rearward. I also google'd a couple photos of various 2.5/4.0's and the numbers are "right side up" when looking at the bottom of the engine and the snout is to the left. Make sense? :nuts: Anyways I reversed the caps and the assembly rotates fine. Link to comment Share on other sites More sharing options...
