Drive Shaft
Ok, I am going to be getting a 8.25 axle from a friend to replace my D35.
As my sig says, LWB AW-4 4x4
So make sure I have this all straight,
AW-4 + Chrysler 8.25 = -1" on Drive shaft I have now.
AX-15 + Chrysler 8.25 = 0" taken off of DS I have now.
If the above is correct, I do not want to cut my DS down because I
plan on swapping in the AX-15, but do not have the money for it yet,
plus I need the axle put in soon/now.
So I guess the real question is, are there any other vehicles out there that you all
know of that the DS would work for my MJ? If its to long I can have it cut down no problem,
but I just don't know if it would work. And the chances of me finding another MJ right now with
the correct DS I need are kinda slim.
Look at the rust marks on the slip yoke. It is quite possible your drive shaft is short enough to work.
this is on the Jeep with a 3" lift?
:clapping: Sorry Pete. I'm sure right now with all the stress about your fleet being
threatened that your reading comprehensive skills are bit on the low side right now. :rotfl2:
I will look. but I believe Correy has a fix for my problem.
