Squeaky leaf springs.
They make sheets you can put between the leafs to combat that.
:agree:
Long term - you may need to loosen up your spring pack (or at least take the pressure off of them) to slide these in. The squeaking can (and likely is) also be your shackle bushings/bolts.
Short term - nothing wrong with lubing them up. I have done that before with great results
