I did some searching, but didn't quite find what I was looking for. I'm getting ready to tackle my 4wd transmission/transfer case swap. I have a combo from a '95 XJ with the external slave and the CJ pilot bushing. The question is, will my current clutch work ('90 2wd AX-15) or will I need to buy a new clutch to match the '95 4wd AX-15 transmission? Also, is there anything else I should look at replacing while I'm doing this?
Personally, I would get a new clutch and replace everything anyway, simply for piece of mind. Plus, with the 95 clutch kit, you'll get a new throwout bearing, which is something that's never a bad idea to replace when the trans is out.
