Is there adjustment on the ignition timing on a 2.5 TBI? The casting of the ditributor has a saddle the locates to the clamping screw. That tells me if it is not inserted to the perfect position the timing will be off? I can see 0 to 20 degrees marked on the timing cover. You could be off one tooth when you insert the distributor, then where is your timing going to be? The manual tells you to be sure the oil pump is in the 3:00 o'clock position before inserting the distributor, does that set the timing?
:agree: your timing will be i think 10 degres advanced when running the cps tells it when to fire so if cap and rotor are in the right place it will run if not it won't
Correct, you can not adjust the timing manually, but the timing marks are on the cover are still there to verify the actual TDC timing advance and most importantly the stability of the timing under different RPMs by using a timing light. Slop in the dizzy and/or a worn dizzy gear among other causes can be detected quickly, and the timing light is still a valuable troubleshooting tool. :cheers:
