Oizarod115 Posted October 19, 2006 Share Posted October 19, 2006 i was gonna ask this in robbie's taillight thread but i do enough hijacking as it is. Ive got a 5spd and i don't think the reverse lights work. should they come on with the key in run (engine not running) and the tranny in R?[/i] Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted October 19, 2006 Share Posted October 19, 2006 you need to turn it into the step before the start position for them to come on. The Acc spot (if you can get it, trick. hold down the release tab and twist backwards on the key) won't activate them either. Check the fuse. mine was sitting just slightly out and it was fooling with my rev. lights. and last but not least, wiggle the bulbs, shake the harness below the bed and the tranny sensor. Link to comment Share on other sites More sharing options...
RandysMJ Posted October 19, 2006 Share Posted October 19, 2006 There's 2 fuses, 1 is labeled reverse lights (i think), the other is marked "trans". Mine wasn't working when i bought it. I looked and the fuse for reverse lights was still good. Then i read around on here and someone mentioned that the 5 spd also uses the "trans" fuse. So i checked and my there and wasn't a "trans" fuse installed. So i put one in and it worked. Link to comment Share on other sites More sharing options...
Pete M Posted October 20, 2006 Share Posted October 20, 2006 Other issues can be a bad switch (located in the passenger side of the trans I think) or corrosion in the harness connector located right behind the drivers side rear tire. Link to comment Share on other sites More sharing options...
