bkdrocks Posted April 27, 2010 Share Posted April 27, 2010 Can you use a shaft out a NON CAD D30 axle in a CAD D30 axle ? Link to comment Share on other sites More sharing options...
akamcbird Posted April 27, 2010 Share Posted April 27, 2010 yes, bigger ujoints... but,the pass. side tube seal is differnt.(i think :hmm: ) ive heard of people sanding the shaft at the proper place so it will seal, or put the appropriate seal in next to the carier Link to comment Share on other sites More sharing options...
Oizarod115 Posted April 27, 2010 Share Posted April 27, 2010 yes, bigger ujoints... but,the pass. side tube seal is differnt.(i think :hmm: ) ive heard of people sanding the shaft at the proper place so it will seal, or put the appropriate seal in next to the carier the u-joints are not bigger just because it's a non-cad axle.. it has to be a late-model or an early model with ABS to have big u-joints. otherwise they'll be just as dinky as the ones you have. you can also find a 95 yj with a CAD axle with big ujoints. yes, you can put the single axle in the CAD axle housing, you will need a differnt axle seal though Link to comment Share on other sites More sharing options...
