bkdrocks Posted April 20, 2010 Share Posted April 20, 2010 Is there a difference in the 2 crossmembers? or a difference in the way they are bolted to the frame? Rough country has a long arm upgrade kit for the XJ but say the crossmembers are different and it will not fit an MJ? Any info will be appreciated. Link to comment Share on other sites More sharing options...
Geonovast Posted April 20, 2010 Share Posted April 20, 2010 XJ / MJ crossmembers are the same. The unibody is slightly different however, so it may tie into that, and that's why it won't work. Link to comment Share on other sites More sharing options...
Hubbell Posted April 21, 2010 Share Posted April 21, 2010 PM sent and for everyone else it's the same. The kit does work just fine on the mj. The only things are the extra supports for the lower control arms and notching the cab supports. Everything else is the same as an xj. Well worth the money. Link to comment Share on other sites More sharing options...
bkdrocks Posted April 21, 2010 Author Share Posted April 21, 2010 Thanks for the help and info! I will post pics as soon as it comes in.On back order for 2 weeks..... Link to comment Share on other sites More sharing options...
