AX5 value?
wallisek
Got my 2.5 in the machine shop right now and in the process of rebuild my NP231. I didn't plan on putting a used high mileage transmission between the two. What would be a reasonable price to pay for a used one? I see a couple in my local area on craigslist for 150-350. I'm thinking 150 since a rebuild kit with synchros is around 200 assuming I rebuild it myself. I ran across an AX-15 + bellhousing for 150 but from what I understand I can't put the 15 behind my 2.5. :(
You need a somewhat rare 2.5/AX-15 Dakota bellhousing, and also need some fancy shift linkage work, trans mount work, and different driveshafts.
After all that cost, you might as well have bought the rebuild kit for your AX-5 and kept things easier. The AX-5 is a good enough trans for a 2.5.
Most I would go for a decent one is 150, maybe a few bucks more if it comes with an external slave setup.
