Where do these vaccum lines go?
These obviously connect to each other, but I don't know which one connects to which.
And this one has a bolt in it (capped off). What is it for?
I hear a sucking sound when my clutch isn't pushed in, so I figure this might have something to do with it. :dunno:
If you want new lines here are the parts you need that you can get from NAPA.
7151367 from cover to connector
7151366 from connector to air box
7151365 from cover to air box
If you want to reconnect the broken ones here's the vac. diagram (4.0L right?):
