ahmincha Posted April 15, 2010 Share Posted April 15, 2010 Hi everyone, Couple ?s going to convert to 4wd what i need to no is will front and rear diff and drive shafts out of a 86 2.5 comanche work in the 92. I also have access to diffs and drive shafts out of a 90 with a 4.0 in it . next ? will the trans and transfer case out of the 90 work in the 92 both are complete trucks. Any pros or cons to either one thanks in advance. I will take pics and post them when i start Link to comment Share on other sites More sharing options...
akamcbird Posted April 15, 2010 Share Posted April 15, 2010 what are the specs of your '92? what are your future goals for this truck? if '92 has a 2.5 use 2.5 axles for the lower gears, if it has 4.0 and you plan to lift it you may want the lower gears of the 2.5 axles. mounting is the same remember when ordering axle parts, bearings brakes etc. they changed through the years tranys will swap to like motors, but for eze use like transmitions Link to comment Share on other sites More sharing options...
ahmincha Posted April 15, 2010 Author Share Posted April 15, 2010 the 92 is a 4.0 5 speed basic use is to plow my driveway and run around locally. Link to comment Share on other sites More sharing options...
ahmincha Posted April 19, 2010 Author Share Posted April 19, 2010 am i right that i need a trans from a 91 or 92 and if thats the case do i also need the tc from same year Link to comment Share on other sites More sharing options...
