1990 2.5 ax5. When i start it up it idles normal. Then when it warms up sitting at a stop the idle drops down around 200 rpm. Any ideas thanks
I have the same problem in my 89' 4.0. starts good, rpm shoots then settles around 4-5 sometimes going up to 5-6 but the low idle always prevails. always starts, always strong.
Yep mine runs good runs strong jest has a low idle.
Does anybody know if you can adjust a tbi. I also forgot to mention it is a rough ido. thanksl
If the IAC is good *and clean*
There is a small adjustment screw on the back of the TB throttle arm that can be adjusted for idle.
Seam to know someone whom used a manual TB with a AW4 swap, and had to make this adjustment :D
Generally, the IAC will cause high idle at start-up, and rough idling.
Also check your MAP, make sure the vacuum line is clear and connected on both ends.
Another possible cause is the EGR valve, I had one so bad, it would choke the engine right out, I disconnected it, and plugged the vacuum line *we don't have sniffer test here on anything before '96*
And.......while your at it, check ALL the vacuum lines, one loose/cracked hose could cause rough idling.
On the vacume lines were they all go together by the valve cover. Is this something i can buy at auto part store. i don't know what it is called
:hmm: :dunno:
You mean the tree??? Where all the lines connect???
I don't think a parts store would have a part like that.........JY is your only bet. You could check the "Help" section to see first :dunno:
I will try that. I am tired of giving it gas at a stop to keep it from dying
