Brenton Posted June 12, 2010 Author Share Posted June 12, 2010 I ordered in a Rusty's intake tube and was able to install it yesterday. Its a very simple setup...it uses the factory tube and just replaces the whole air box assembly with a bracket and K&N air filter. Probably took about 20 minutes, and it would have been less but I had to do a little "customizing" (see pics). the old junk the new stuff the custom work....i had to use a little factory part; drill two holes in the end of the filter so I could tap a small line Link to comment Share on other sites More sharing options...
snowboard3r411 Posted June 14, 2010 Share Posted June 14, 2010 Love ur manche good job man Link to comment Share on other sites More sharing options...
Brenton Posted December 29, 2010 Author Share Posted December 29, 2010 Soooo it turns out that Comanches run quite a bit better when they have a properly functioning fuel pump. :shake: My MJ had been running a little odd....right after start up, it would run fine, but if I proceeded to drive around town awhile, it got to the point where it would drive, but not very well. I worked off of a few pointers from the tech forum here, thanks everyone :cheers: ....right as I was going to change the fuel filter, the Jeep went *blaaah*. Thankfully I was still in my driveway. I changed the filter...nothing...but I realized when I turned the key, that I couldn't hear the pump humming...with a little help from my dad, my girlfriend (yeah, she actually crawled under the truck to lend a hand :yes: ), and a few choice words, my Comanche is one small step closer to greatness. Link to comment Share on other sites More sharing options...
btm24 Posted December 29, 2010 Share Posted December 29, 2010 great right up one the air filter. I may just do this insted of buying an intake from rusty's off road. Brandon Link to comment Share on other sites More sharing options...
Brenton Posted December 29, 2010 Author Share Posted December 29, 2010 I forgot to post these earlier.....I decided it was time for black flares. The paint was bad and I wanted the new look, so.... Link to comment Share on other sites More sharing options...
Brenton Posted December 29, 2010 Author Share Posted December 29, 2010 great right up one the air filter. I may just do this insted of buying an intake from rusty's off road. Brandon Yeah it was very simple to do, and I know my way around tools but I'm not exactly "mr. fixit". I thought the price was very reasonable too. I read your MJ build...I plan on running a snorkel also and I'm considering running some sort of exhaust that resembles a military humvee. I bought this intake because, first it was a good price, second, when I do install the snorkel, I will put this intake on my Cherokee...so it won't just be thrown away. Link to comment Share on other sites More sharing options...
btm24 Posted December 29, 2010 Share Posted December 29, 2010 There is a kid at school who ran his exhaust though the bed behind the cab and behind the tool box kinda like a stack for semis. Not only does it sound better then I would have expected he dose not have to worry about his engine cutting off due to water clogging it up. It sounds amazing. The only reson I ever thought about a snorkel is because I sunk my truck and never wanted to deal with hydro locking ever again. After seeing the cost of a real kit and not a PVC pipe rig up. Now that I have a k&n filter and don't do much Off roading I can't see spending $300+ to cut a hole in my fender. And I'll be doing that filter thing within the week. Brandon Sent from my iPad3G Link to comment Share on other sites More sharing options...
Brenton Posted January 8, 2011 Author Share Posted January 8, 2011 I was lookin through the DIY rightups the other day and I ran across CC member Fire4755's custom cupholder. I decided to use his method but modify it for my truck. I also have a manual with a bench seat, but I do not have the factory center console anymore. I got tired of not having a place for a cup, so..... Note the high quality custom fabrication :roll: this is how it was before all the steps from cardboard stensil to sanded individual pieces "mock up" finished console/cup holder Its actually a lot cleaner looking finish than the overkill of a flash makes it look. I'm happy with it! :D Link to comment Share on other sites More sharing options...
Brenton Posted February 16, 2012 Author Share Posted February 16, 2012 I guess its about time for some kind of update...the Jeep has been through a few small mechanical fixes, 4x4 not working (fixed now), sold the black steels with Goodyear MTRs, got the stock turbines back on (for now). Looking to upgrade the lift. I want to go to a 4.5" lift with some new wheels and 31x10.50 Mickey Thompson MTZs. No major changes, just driving it all I can. Link to comment Share on other sites More sharing options...
Brenton Posted February 29, 2012 Author Share Posted February 29, 2012 Got some "new" BFG Mud Terrains today. They should hold me over for now :D Link to comment Share on other sites More sharing options...
Brenton Posted March 1, 2012 Author Share Posted March 1, 2012 Something about this Jeep, that I somehow completely missed when I was test driving it, was the steering column job. I don't know why it was swapped, but it is obviously not the original. Aaand something was broken...so the PO decided the best fix was to wrap the column in a coke bottle, zip tie it, and paint it to "match" (see picture of interior on first page...you can just see the bottom of the column). I'm all for home brew fixes, but come on :shake: Besides cosmetics, nothing is wrong with the steering so I didn't want to pull it all out. So, I found a piece of tin, cut it to size, and.... ....its already 10x better, as far as I'm concerned. I plan on painting the rest of the column black or gray, and then replacing the steering wheel. Oh yeah, I also swapped out my grill for a 10 slot grill :thumbsup: Link to comment Share on other sites More sharing options...
