vaquaro Posted April 3, 2010 Share Posted April 3, 2010 :dunno: Changing V.C. gasket from RTV to Fel-Pro dry gasket , OEM bolts have shoulder and don't work with the dry gasket , what length(s) do I need ? Link to comment Share on other sites More sharing options...
Eagle Posted April 3, 2010 Share Posted April 3, 2010 V.C.? Vacuum canister? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 3, 2010 Share Posted April 3, 2010 Using the FelPro gasket w. the 4.0 is no problem, but notice you have a 2.5. So what's the difference with the VC bolts? What do you mean by shoulder? :hmm: Link to comment Share on other sites More sharing options...
jteckmann Posted April 3, 2010 Share Posted April 3, 2010 I just replaced the gasket on my 2.5 I used 1/4"-20 thread, 1/2" long. Link to comment Share on other sites More sharing options...
vaquaro Posted April 3, 2010 Author Share Posted April 3, 2010 V.C.? Vacuum canister? :hmm: or Viet-Cong :rotf: Link to comment Share on other sites More sharing options...
vaquaro Posted April 3, 2010 Author Share Posted April 3, 2010 I just replaced the gasket on my 2.5 I used 1/4"-20 thread, 1/2" long. Was that the OEM size used before RTV gaskets ? Link to comment Share on other sites More sharing options...
vaquaro Posted April 3, 2010 Author Share Posted April 3, 2010 Using the FelPro gasket w. the 4.0 is no problem, but notice you have a 2.5. So what's the difference with the VC bolts? What do you mean by shoulder? :hmm: Shoulder is the larger diameter unthreaded portion of the flange bolt , :cheers: presumably to define the RTV gasket bead dimension Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 3, 2010 Share Posted April 3, 2010 Then just use 1/4"x20x1/2" or 3/4" if it's not too long all-thread bolts torqued to spec. w. sealant on the bolt threads. I don't have a shoulder (non-thread portion of the bolt) on my valve cover bolts. Link to comment Share on other sites More sharing options...
jteckmann Posted April 3, 2010 Share Posted April 3, 2010 Was that the OEM size used before RTV gaskets ? I don't know if the old ones I pulled out were OEM or from a previous owner. They were a different length - maybe 5/8"(?) But at the parts store, they only sold 1/2" and 3/4", so I just grabbed a pack of each. I was worried about bottoming out the 3/4", so I started with the 1/2" - and they worked fine. Just regular grade 5 bolts with a flange head and no shoulder. Link to comment Share on other sites More sharing options...
vaquaro Posted April 3, 2010 Author Share Posted April 3, 2010 Was that the OEM size used before RTV gaskets ? I don't know if the old ones I pulled out were OEM or from a previous owner. They were a different length - maybe 5/8"(?) But at the parts store, they only sold 1/2" and 3/4", so I just grabbed a pack of each. I was worried about bottoming out the 3/4", so I started with the 1/2" - and they worked fine. Just regular grade 5 bolts with a flange head and no shoulder. Thanks , I'll source some from Fastenal (probably 5/8" ) and get to work on curing this ongoing oil leak problem , hopefully for good :thumbsup: Gord Link to comment Share on other sites More sharing options...
Eagle Posted April 3, 2010 Share Posted April 3, 2010 Consider using Loctite on the threads of the new bolts. Squirt some brake cleaner into the holes in the head to degrease the threads. Put Loctite on the bolt threads and let it partially set up, then tighten. Don't use red -- that's permanent. Blue would be okay (medium hold), or probably even purple (light hold/small fastener). Link to comment Share on other sites More sharing options...
vaquaro Posted April 4, 2010 Author Share Posted April 4, 2010 Consider using Loctite on the threads of the new bolts. Squirt some brake cleaner into the holes in the head to degrease the threads. Put Loctite on the bolt threads and let it partially set up, then tighten. Don't use red -- that's permanent. Blue would be okay (medium hold), or probably even purple (light hold/small fastener). :agree: Link to comment Share on other sites More sharing options...
