Bonkers Posted October 11, 2006 Share Posted October 11, 2006 I have a notoriously bad window regulator that I can't seem to get a decent repair price on. I have a friend who just took on a sacrifical 88 Xj and he offered me the doors with power windows. I've read posts here about how this is an 'easy' swap, but what parts would I need to take to make it basically bolt-in? I assume my Mj door shells could be used with minor effort right? Link to comment Share on other sites More sharing options...
87manche Posted October 12, 2006 Share Posted October 12, 2006 the doors themselves will fit on with no mods. You'll need to grab the power window harness to make all that work without any issues. Link to comment Share on other sites More sharing options...
Bonkers Posted October 12, 2006 Author Share Posted October 12, 2006 Yeah, the headache is that the doors are blue and the Mj is red. I can grab the harness no prob, anything else I should look for? Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 12, 2006 Share Posted October 12, 2006 If your "sacrifical 88 Xj " was a 4-door, you will have some wiring issues, because the driver master control switches are for all 4 doors, and the associated wiring. Will work if you snip off the drivers door harness for the 2 rear doors, but then you will have a drivers master control with 2 dummy switches for the rear doors. The best/easiest way is to find a 2-door XJ power window harness (or MJ power window harness - lots of luck), which includes the power door locks. You'll also have to get the drivers side master control switches from the 2 door XJ. The passenger door switches are the same. Link to comment Share on other sites More sharing options...
87manche Posted October 12, 2006 Share Posted October 12, 2006 I hadn't thought of that issue. I'd just disconnect the extra 2 switches, maybe use them for something else. Link to comment Share on other sites More sharing options...
lostissues Posted October 12, 2006 Share Posted October 12, 2006 like a passanger ejector seat switch :popcorn: Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 12, 2006 Share Posted October 12, 2006 like a passanger ejector seat switch :popcorn: :rotfl2: Link to comment Share on other sites More sharing options...
