Geonovast Posted March 23, 2010 Share Posted March 23, 2010 Take the old end into your favorite parts store, so you can match up a replacement. Link to comment Share on other sites More sharing options...
MCF90 Posted March 24, 2010 Author Share Posted March 24, 2010 Can do! Guess I'll need the pickle forks after all! :doh: Matt Link to comment Share on other sites More sharing options...
Eagle Posted March 24, 2010 Share Posted March 24, 2010 I'm thinking I may need to replace the chassis end rod end as the rubber boot is toast. Where could I find a replacement? Matt You can get replacement boots on the HELP! rack at Auto Zone or Advance Auto. If the TRE itself doesn't feel sloppy, just buy a new rubber seal. Link to comment Share on other sites More sharing options...
MCF90 Posted March 24, 2010 Author Share Posted March 24, 2010 Matt You can get replacement boots on the HELP! rack at Auto Zone or Advance Auto. If the TRE itself doesn't feel sloppy, just buy a new rubber seal. Cool, I may be able to just do that. The joint doesn't feel worn out, so I guess I could get away with just buying the boot. Thanks! Matt Link to comment Share on other sites More sharing options...
ovrszd Posted March 24, 2010 Share Posted March 24, 2010 Heat. If no heat, a bigger wrench or cheater pipe. Maybe moderately tap around the tube where it's threaded on, careful to not dimple it. Link to comment Share on other sites More sharing options...
MCF90 Posted March 28, 2010 Author Share Posted March 28, 2010 Well, I finally got the old rod end off! A little heat from a propane torch and a pipe wrench finally broke it loose. Stopped into O'Rielys and got a replacement. Just have to slap it all back together and that will be one more little chore off my list! Matt Link to comment Share on other sites More sharing options...
Geonovast Posted March 28, 2010 Share Posted March 28, 2010 :clapping: Link to comment Share on other sites More sharing options...
Automan2164 Posted March 29, 2010 Share Posted March 29, 2010 :yes: Congrats. Rob L. Link to comment Share on other sites More sharing options...
MCF90 Posted March 29, 2010 Author Share Posted March 29, 2010 Thanks guys! Next project will be adressing the drivers floor. I've got the replacement pan, need to do some trimming and then fit the new pan. Only problem is, I've only got access to an arc welder. Not sure what I'm gonna do there. Once I figure out the floor, then I can move on to installing the new clutch master cylinder and any other small odds and ends I find. Matt Link to comment Share on other sites More sharing options...
