88pioneer Posted March 22, 2010 Share Posted March 22, 2010 or something similar http://motionoffroad.com/catalog/index. ... ucts_id=16 Link to comment Share on other sites More sharing options...
88pioneer Posted March 22, 2010 Author Share Posted March 22, 2010 i see someone has changed my title ;) Link to comment Share on other sites More sharing options...
lostissues Posted March 22, 2010 Share Posted March 22, 2010 it looks like a rugged ridge setup (http://www.jcroffroad.com/Merchant2/mer ... ry_Code=S6) Link to comment Share on other sites More sharing options...
comanche09 Posted March 22, 2010 Share Posted March 22, 2010 Grab a V8 ZJ Tie rod. It's cheap and beefy. Or, Before I'd spent $250+ for that, I would look into a WJ high steer setup conversion, sourcing JY parts of course. Link to comment Share on other sites More sharing options...
Blue XJ Posted March 22, 2010 Share Posted March 22, 2010 I'm running a similar setup, its not really cross over though, its inverted 'T'. I've had good luck with it, but if you don't get a poly spacer under the right tierod the steering will roll when you turn which results in a dead spot in the center of the wheel when you go back and forth. you can kind of see it here, mine is also over the knuckle for more clearance Image Not Found Link to comment Share on other sites More sharing options...
