Bent rear Bumper Brackets?
The book shows 6 bolts on each side holding the bracket. However every MJ I've looked at only had 4. one going up from the bottem just to the rear off the spring mount and three going in from the side. Above the spring mount. Then there's the wires for the LP lights.
I straightened my rear bumper by jacking up the truck by it, then jumping on the tail gate a few times. After that I backed it into a tree a few times. Then I bolted it to my frame mounted hitch to keep it straight.
Didnt even need a BFH huh? :rotf:
