rear brake line fittings
What size are the brake line fittings for the rear axle? It is actually for my 94xj with an 8.25. The brake line i bought has the wrong size fittings. Now i have to track down the fittings and cut and flare the line :fs1:
They should be normal 3/16" line fittings. I replaced the rear hose and rear lines to the wheel cylinders on my dana 35, but they should be the same. If you don't think they are just call the parts store and ask them what size the fitting is on the replacement wheel cylinders.
I rented the double flare tool at autozone for free and made them myself, very nice clean install with great results. Advance auto should have the same rental tools,if not the flare tool is only around $30.
