clutch line
so i ended up replacing the last bit of the old line,
was pretty stoked, i had preasure,
but still kept on getting air bubbles,
so i got on my creeper (it belongs in a museum)
and i found this (don't mind the 2x4, it was just to see if i could shorten the spacers for the slave cyl)
this is a clutch line from my newer clutch master cyl,
there is a distinct crack in it, could that make the air leak?
that line was from an internal slave cyl setup
Yes it can make a air leak. It could be acting like a check valve with pleasure holding the crack closed on the in side and letting air in when the pressure is released. :nuts: do you see in seepage of brake fluid around the crack? :???:
