asm4mcc Posted March 5, 2010 Share Posted March 5, 2010 i want comanche buckets or just the mounts thankyou Link to comment Share on other sites More sharing options...
Pete M Posted March 5, 2010 Share Posted March 5, 2010 Are you referring to the floor brackets? They are the same between the bench and buckets. Link to comment Share on other sites More sharing options...
SuperWade2 Posted March 5, 2010 Share Posted March 5, 2010 Are you referring to the floor brackets? They are the same between the bench and buckets. Pete has to correct this every time :smart: , when 99% of the time when people say "brackets", they mean the entire bracket and seat slider mechanism and I'm guessing he very well knows it... Link to comment Share on other sites More sharing options...
Pete M Posted March 6, 2010 Share Posted March 6, 2010 I like to be thorough. :D The floor brackets are the big missing part needed to mount up XJ buckets. Link to comment Share on other sites More sharing options...
asm4mcc Posted March 6, 2010 Author Share Posted March 6, 2010 if the mj bench and bucket are the same then how do u make it work with a xj seat Link to comment Share on other sites More sharing options...
Pete M Posted March 6, 2010 Share Posted March 6, 2010 There are 3 components to a seat, the floor brackets, the sliding track, and the seat itself. The floor brackets are shared between the MJ bench and MJ buckets, but they don't share the track (the bench has half a track on each side). XJs and MJs have very different floors, so they do not share the floor brackets. But the XJ bucket track can be adapted to the MJ floor brackets. So to install XJ buckets, you need the complete XJ buckets, remove the XJ floor brackets, and attach the MJ floor brackets. But be aware that not all XJ buckets are made the same. There are 3 different types of track assembly, and 2 different kinds of seats. Track assemblies: -straight sliding -curved sliding -power the straight is the one you want. the curved will raise the seat up like 3" and the power assembly is huge and a real pain to install. As to the seat itself, 4-door XJ seats do not lean forward like MJ buckets. But 2-door XJ seats do. 2-door are preferred, but it's not a deal breaker if you find a nice set of 4-door seats. Several members have them and have gotten used to sliding the seat forward to access the rear area. Link to comment Share on other sites More sharing options...
