Rymanrph Posted February 22, 2010 Posted February 22, 2010 I need to get all the linkage components for my 4wd swap, but I really don't know what I'm looking for. I pulled what I could out of an '89 auto, but mine will be an AX-15. Does anyone have pictures of the different components or a diagram so that I can assess what I have?
comanche09 Posted February 22, 2010 Posted February 22, 2010 This would be a good sticky thread if they could all be identified. The best I got was grab all that you can and mix and match parts... My swap is a bit further complicated in that I am using the AX-15 with the NP242.
LEAD_NOT_FOLLOW Posted February 22, 2010 Posted February 22, 2010 NP231 Service Manual http://www.greatlakesxj.com/tech/NP231-Component-Service-Manual.pdf
mjeff87 Posted February 23, 2010 Posted February 23, 2010 there are three parts of the linkage specific to the AX15 that you'll need..... the trunion bracket that bolts to the tranny tunnel that has the little orbital joint in it the trunion bracket that bolts to the tranny/transfer case studs the rod that connects the trunion to the range selector on the TC The floor shifter and the trunion contraption are the same for all tranny models Jeff
Rymanrph Posted February 23, 2010 Author Posted February 23, 2010 there are three parts of the linkage specific to the AX15 that you'll need..... the trunion bracket that bolts to the tranny tunnel that has the little orbital joint in it: I have this piece from the auto, so I have some idea what it looks like. the trunion bracket that bolts to the tranny/transfer case studs: I think I have an idea of what this is based on what I looked at on the auto. the rod that connects the trunion to the range selector on the TC: not entirely sure on this one The floor shifter and the trunion contraption are the same for all tranny models: I guess this is the only piece that I got that is worth anything (to me at least). Jeff That's great information really, but I'm a visual person. I'd still love to have some pictures or diagrams.
mjeff87 Posted February 23, 2010 Posted February 23, 2010 Image Not Found #14 is the bracket that bolts to the tranny tunnel....the little heim sits about 1.5" to the rear on the AX15 part (it's centered on the other ones). #31 is the bracket that bolts to the tranny #15 is the rod that connects the linkage to the TC Jeff
Rymanrph Posted February 23, 2010 Author Posted February 23, 2010 That's great! Now I just have to find those pieces. Are the AX-15 pieces different than the Peugot components or are they interchangeable?
