streetjeep2.5 Posted February 16, 2010 Share Posted February 16, 2010 For my 87 MJ Jeep parts dept can supply new pins, but bushings are obsolete. Whatcha guys done to fix a wobbly upper hinge a the pin? Dorman make anything to work? Other supplier??? Will pin an bushing for later hinges work? Link to comment Share on other sites More sharing options...
deziped Posted February 16, 2010 Share Posted February 16, 2010 My 88 & 89 didn't have bushing in the hinges, they only had a split pin. I pulled the doors off punched out the pins and then just drilled the pin hole in the hinge out to 1/4" or maybe 13/64 and it cleaned it up enough so I could drop a greased up 1/4" bolt into the hinge. Worked good, no slag or slop in over 2 years now. Link to comment Share on other sites More sharing options...
streetjeep2.5 Posted February 16, 2010 Author Share Posted February 16, 2010 Took the word of the parts guy at the jeep dealership that "bushings were no longer available" for pre-91. No bushings, eh? According the that same parts dept., the later hinges replace the older, so maybe they went to pins and bushings since that's what they show for the later models. Wonder if I could drill out to the busing size and install later pins and bushings? Have to see. Or, do the bolt thingie. :cheers: Link to comment Share on other sites More sharing options...
Geonovast Posted February 16, 2010 Share Posted February 16, 2010 Doors are overrated. :idea: Link to comment Share on other sites More sharing options...
Oizarod115 Posted February 17, 2010 Share Posted February 17, 2010 i've never seen bushings in a cherokee/mj door... ? Link to comment Share on other sites More sharing options...
streetjeep2.5 Posted February 17, 2010 Author Share Posted February 17, 2010 MJ and XJ use same hinge according to Jeep, so ... http://www.jeep4x4center.com/product-in ... er=4638276 Link to comment Share on other sites More sharing options...
Oizarod115 Posted February 17, 2010 Share Posted February 17, 2010 Huh... Huhhuh... Bevis laugh... I was thinking about the door stop pin whoops! Link to comment Share on other sites More sharing options...
