Bonkers Posted September 29, 2006 Share Posted September 29, 2006 I just scored a deal on some bridgestone duelers (my personal favorite tire.) The tires fit almost perfectly in the well, but under full turn they rub up against the suspension arm. Is there anything that can be done to prevent the wheel from turning this sharply? I only need to cut about 1-degree off the angle. Link to comment Share on other sites More sharing options...
Pete M Posted September 29, 2006 Share Posted September 29, 2006 WJ control arms! :D Or remove the steering stop bolts and put a washer behind them. Link to comment Share on other sites More sharing options...
aemsee Posted September 30, 2006 Share Posted September 30, 2006 I see ya haven't modifired those dubjay arms yet. Had a set on my 93 ZJ and did a couple of sets for friends. Too bad they weren't just a couple inches longer. Link to comment Share on other sites More sharing options...
Pete M Posted September 30, 2006 Share Posted September 30, 2006 I'm modifying them right now! :D Well, ok, so right now I'm typing, but I'm also in the middle of getting the drivers side in. :roll: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted October 2, 2006 Share Posted October 2, 2006 The WJ arms are nice and will improve ride as well as tar clearance. BUT all you need to do is adjust the steering stops and call it good, NO MORE RUBBS!!! CW Link to comment Share on other sites More sharing options...
